Location: Renegade Zone \ Renegade Zone \ Editing \ help me plz.. Back to Threads |
mar14vin
![]() Joined: 17 December 2003 Posts: 2 |
17 December 2003 16:30 (UK time)
i downloaded renegade tools installer 2 but it doesn't work, must i download something else?? You need to login to create posts in this thread. |
![]() Joined: 02 February 2004 Posts: 90 |
18 June 2004 20:37 (UK time)
well i downloaded it from here and it works fine mabey u never downloaded gmax yet u can figure that out by look at ur level edit if that works but not renx then u dont have gmax You need to login to create posts in this thread. |
27 January 2005 01:12 (UK time)
i had a problem like that but all i had to do was delete both of em then download them in the opposite order instead of rentools installer 2 then gmax, gmax then renegade tools installer 2 You need to login to create posts in this thread. |
