Renegade Zone  \  Renegade Zone  \  Editing  \  HELP WITH FIRST MAP
Viewing Thread: HELP WITH FIRST MAP
Sciron21
13 April 2005 05:32 (UK time)
ok i installed Gmax And whatnot and renX and stuff but wenever i start up renX its Says and i quote "Interactive 3D Renderer initialization Failed,please check your device settings by using the -H command line option" If Anyone Knows What This Means PLEASE PLEASE PLEASE HELP!!!! thnk you.
17 April 2005 22:39 (UK time)
You probaly need to update your drivers or reinstall gmax
17 May 2005 15:19 (UK time)
im not entirely sure but i had a problem that didnt let me use renX so i got so angry i deleted gmax and every thing i downloaded. So about a month past and i got board with just playing renegade so i downloaded every thing... but in the opposite order (RenX first Gmax second) and every thing started working fine. So mabey u should do that.
But im not sure if it is the same problem u had. My problem had something to do with memory.
try it and tell me if it works.
